SomeGuy133
- Apr 12, 2015
alright so at various points we have talked about how SnapRAID can't tell if a VeraCrypt file was edited because it doesn't change the time on the file.
According to the FAQ in SnapRAID there is a way to enable timestamp updates. I was making a container and I do not see any such option.
Anyone have any clues?
EDIT:
Figured it out. It is not a container setting but a veracrypt prefernce setting. Go into veracrypt prefernces and you will see a box to uncheck.
EDIT:
