SN95G5 wireless networking
Vulcanus
So I heard that th PN15 wireless adapter was really shitty, lost signal, etc.. byut the PN15g was really good? All I can find available to buy is the PN15 though? I really can't use my PCI slot as my sound card took that slot and I don't trust the wireless ones because they have almost nothing for an antenna.
Do they even sell the PN15g's?
Well for many wireless products people claim g series are better. Many of them think on 54 Mb standard when they say g technology. Well I don't know how good is a Shuttle Wireless adapeter but I know what is good option for all PC's :)
I've took USB2 Edimax EW-7113UHg and it works great.
It has small "dish" that in combination with good electronics makes 6 db amplification.
In real life if You just can't overbridge connection with normal wireless card (like 1% signal strenght) with this one You will have min. 30% signal strenght. It will overbrigde nice distance and for close distances latncy will be strongly improved.
Also it can work on any PC with USB. Hence You can use it on XPC and then take it with You and use it on PC from Your friend or family member.
Edimax page s*cks :(
http://www.edimax.com/html/english/products/list-wireless.htm then You can see it. Though clicking on that link brings me nothing :(
Edimax EW-7113UHg works very good with SN95G5 ( I have it also :) ) and it works very good.
Just found some data for it on google :
http://wirelesshomes.co.uk/edimax/ew7113uhg_files/f-main.html
MD
