sn41gv3 low sound output
leeroy
i am outputing my onboard sound to the cheap HP polk audio 2 speaker setup however the soud output is very very low. lower then headphones . really sux. anyone has same problems?>
ive installed the drivers,
connectors are fully plugged in
tested with headfones which is really louder
turn volume max in windows
turn volume max in nvidia manager
tested the same port to AUX in my hifi which is hwo it should have sounded like
therefore i htink i conclude i got scrap sound level output to my cheap hp polk audio 2 speaker setup since i think i need power ac mains driven speakers?
note the cheap hp polk audio 2 speaker setup works ok on my hp pc. very loud of course so speakers are ok
Unpowered speakers rarely work well. I had a k7s5a board a while ago that had an output amp so low powered I could barely hear when using headphones. Powered speakers worked fine with it though.
Like he said, unless you have an external amp (or externally powered speakers) you won't get much volume out of it!
