SN41G2V2 Questions
Youhou
Hi, please answer these questions or direct me to the answers is possible.
1. Can I use an AMD mobile Athlon XP 2500+ in this shuttle?
2. Do I need a video card before I can use DDR400 ram?
3. Does this barebone come with everything I need so that I can just buy the OEM versions of the rest of the parts?
I'm a newbie (obviously) at building computers so if you have any suggestions or advice I'm open to hearing them.
The Specs if you don't recognize this model immediately:
Specifications:
CPU Support: AMD Athlon/XP/Duron (Socket A, Max.FSB 333)
Chipsets: nVidia nForce2 / MCP-T
Memory: 2x 184pin (DDR400 up to 2GB)
IDE: 2x ATA133
Graphics: Build in Geforce4 MX
Expansion Slot: 1x PCI, 1x AGP 8X
Audio: Realtek ALC 650 supports 5.1 channel audio
LAN: On board Realtek 8201BL
Extension Bay: 2x 3.5", 1x 5.25"
Front Panel Ports: 2x USB, 1x 1394, 1x SPDIF_Out, Audio ports
Back Panel Ports: 2x COM, 2x PS/2, 2x VGA, 1x S-Video, 1x RJ45, 2x 1394, 2x USB, Audio ports
Power Supply: 250W Silent X (PFC)
Dimensions: 11.8 x 7.9 x 7.3 in
Thanks.
i ran mine at 210 with a single stick of ram.. it worked.. but i knew i wasn't supposed to do it.. so i bought a video card...
that shuttle will work great for overclocking.. you can adjust the multi from something like 6 - 20.. the vcore from 1 - 2v.. don't touch the vdimm though.. get memory that can run well at low voltages..
i would get the sn45gv2 though.. and a vid card
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-230R&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-230&depa=0
those 2 would be every bit as good as that mx 440....
http://www.newegg.com/app/viewProductDesc.asp?description=56-101-455&depa=0
get that.. i would have, but it didn't come out until a month after i bought my sn41g2v2..
but with an agp card, the 41 will handle 200+ fsb with no problems
also.. i say this over and over.. but get a 2400+ 35 watt, or a 2600+ 45 watt.. don't get the 2500+ 45 watt.. becasuse the 35w 2400+ is the same damn price and has a lower stock voltage... 1.35 vs 1.45 it gives you that extra .10 v of overclocking headroom, which doesn't sound like much.. but every bit helps...
it comes with all cables, and everything.. you just need a plan cpu.. i would get some arctic silver, it is a good investment for the future...
so, get the 41 if you really like the g2 case.. or you want a black one
or get the 45 if you want to know that it is guarunteed to run 200fsb..
I'll share the same sentiments as scottatwittenberg. The only thing is I would recommend getting a passively cooled video card as that would make the system much more quiet.
Bottom line:
