--MaInFrAmE--
- Jun 25, 2006
Hey freaks,
Last month I bought a new dream machine the SN26P equipped with a AMD FX-60, 2 Gigs of Corsair Twins, 300 Gig Maxtor HD, 2x 7900GT's in SLI mode from ASUS, 300 Gig Samsung extern, NEC DVD COMBO, 19'' DVI ACER
A friend of mine set the machine up without problems and sent it to me (Thailand). After two weeks my Windows crashed and I received fatal error messages in Windows (XP Service Pack2), mentioning that the Event Log File data(s) were lost. I followd a good guide how to setup this system in a stable environment. (SFFtech.com)
Unfortunately, I sometimes get blue screens mentioning a fatal error or i only can move the mouse in windows (no response from the explorer). What could be the problem?
I am afraid to re-install and format the whole HD a third time. Power Supply (350Watt)?
Nvidia AMD chipset driver 6.70 (Only the SMBus driver is installed as the guide recommends only to install this driver and to not install the Audio and NAM driver and especially not the IDE driver which causes the Event log file crashs).
I am located in Thailand, might it be a insufficient power supply from the plug? Further, I use a UPS/ UPC as well, but only for the gameing rig and not for the other devices. CPU/GPU temp. is 42/52 in average.
Sometimes the system does not even start-up - a common Shuttle illness??? Never had a Shuttle before though.
All driveres and BIOS are up to date and for the network drivers I use the AMD/Intel16x network driver as recommended. I am not using Internet at all.
As mentioned bevore no Nvidia 6.70 driver is installed currently, is it even necessary as the NAM, Audio & IDE Drivers are not installed with this driver version?
I still assume it must be the Nvidia chipset driver 6.70. Someone knows when the next driver will be released?????
My friend mentioned to take out one graphic card first, to install the Nvidia Graphic driver (84.21) and then to re-install the second card otherwise the SLI will not be set properly, true?
....HELP.....anyone....please....
Greetz S.
Greetz S.
