Vlad Dracula
- Jan 26, 2006
Hello,
Right, so I have installed the (Leadtek) 7800 GTX into my SN25P and immediately ran into the problem of the card not getting enough power to work at 100% capacity. I have searched the net (thats how I found this forum ) and know by now that a lot of people with the SN25P has got the 7800 GTX to work perfectly with their shuttles. I also know that many people have had the same problem I have. Judging from the info on the net, the solution seems to be to connect the PCI power connector (which splits into two IDE power connectors) to two different PSU channels.
The Problem is that in my SN25P there is only 1 IDE power channel with 2 conenctors and 3 SATA power channels. Id like to use adapters to connect the PCI power connector to two of the SATA channels. Unfortunately there seems to be no SATA to IDE power adapters.
Id be most grateful for any information you can give to help me solve this situation.
Thanks
Thanks
