SN25P - USB - Norton Ghost Conflict
HardKard
Anyone who is *sucessfully* using Norton Ghost (2003, v9 or v10) on their SN25P, could you *please* inform me of your *detailed* system specifications (including BIOS and SN25 mobo revision)? If you've used Ghost and it failed, I'd like to hear from you, too. If you have it, want to try it and tell me what happens, that's cool as well!
I am unable to use the boot-from-cd recovery feature of the program (in multiple versions). It appears to be directly related to the USB system on the SN25 motherboard itself and perhaps the choice of BIOS revision (I am using Y). It might be other hardware, however, so if you can provide more field data for me, that would be helpful.
Your help in trouble-shooting this is greatly appreciated.
If you have experienced *any* problem with the SN25P and USB (**with the exception of the X2 - USB support issue!**) that could be helpful, too.
Thanks!
-hk
What? No one backs up their systems? :)
Or, more likely everyone is using other boot-CDs that include Ghost 9 or 2003, perhaps copies that they "acquired" and so they don't have much to add . . .
C'mon folks, divulge . . .
-hk
