Sn25p Quiet mod
neilnpatel
okay well i have not actually recieved it yet. I RMA’s my sn21g5 and am getting this in return. I personally thought the SN21g5 is quiet but this is supposed to be loud.I am going to order these on sunday so please could you give me some advice.
Northbridge cooler- Zalman ZM-NBF47 Fanless Northbridge Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-023-ZA
Question 1) will this be enough to keep it cool without a fan.
GPU- 7900gt with vf900
Question 2) will i need to mod the case to fit this and can just use the 3 pin connector for the nb cooler
60mm Replacements- Akasa AK-186-L2B Amber Ultra Quiet 60mm Fan - 3 pin x2
http://www.overclockers.co.uk/showproduct.php?prodid=FG-029-AK
Question 3)how will these fit can i simple plug these into a splitter ( see below) and plug taht into the 4 pin socket on the mobo.
Splitter- Akasa AK-FY320 3 Pin Fan cable splitter
http://www.overclockers.co.uk/showproduct.php?prodid=CB-013-AK
Question 4) can this just use 3/4 of the pins and still work without modding.
80mm replacement-Scythe Kaze White LED 80mm Fan - 3/4 Pin
http://www.overclockers.co.uk/showproduct.php?prodid=FG-008-SY
Question 5) i can only replace either the 80 or the 70 due to my budget so which would be better. Also would this work okay.
could i not just use one of these and say superglue it to the back of the case, i want to avoid any permanant mods to my sff.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-007-SY&groupid=701&catid=57&subcat=4
plus i can use the dial to control temps
How loud is the ice system, i have heard people say the ice fans are quiet but the 60mm are loud.
Note=i am planning to oc, and my gfx is oc’ed a lot.
What would you say my bets bet is.
Thanks in advance
