sn25p hardware audio problem in BF2?
Dr. X
Whenever I have hardware acceleration for audio turned on in BF2 the voice commands stutter horribly and are real slow like they're speaking in slow motion. Not the VOIP, but the in game radio commands. When I turn it to software, it works perfectly. I thought the envy24 in the sn25p did hardware acceleration. Anyone know the problem? I'm using the latest drivers from shuttle's site.
Unfortuanately you are out of luck with the SN25P Envy24 and BF2 - the best you can get is Software audio and stereo output. Hardware only works with Audigy2 ZS and X-Fi as far as I know.
I sold my perfectly running and excellent performing SN25P for this very reason - I found that the SB83G5 and SN95G5 V3 work great with BF2 and I can use my Audigy2 ZS and X-Fi cards for true 5.1 surround goodness in BF2! Once you hear the excellent positional audio and environment sounds you will be amazed - well worth the swicth for me!
FYI - I also tried the Creative Audigy2 NX USB exterenal solutionwith my SN25P and it only worked with Software and stereo as well....
god damnit, I'm regretting this switch more and more. I just hope they come out with some PCIe x1 sound cards soon...
Is this just a problem with BF2, or other games also?
I don't understand what you mean by "true" 5.1... I have a set of Klipsch Promedia Ultra 5.1s and I moved from a desktop to my SN25P and notice no difference in 5.1 quality. Just as "true" as before.
I didn't have any issues with my previous games and the SN25P Envy audio (FarCry, HL2, CS:S). They did seem to work well with 5.1 speaker surround. BF2 is the only game that did not support true 5.1 surround.
When I say True 5.1 surround I am referring to positional audio capabilities with Battlefield 2 when using hardware audio and EAX effects with an Audigy 2 ZS sound card specifically.
Believe me - when you hear the difference this makes in your gaming experience! I was blown away from the effects and being able to tell exactly where enemies are at. For example when a tank is approaching from the rear and to the side the appropriate rear speaker is active.
um I enabled hardware audio and it works just fine thanks. medium settings runs nice and clean.
sn25p? Could you please post what drivers you are using, and what your settings in the game and in the Vinyl Audio control panel are? Thanks a bunch.
wtf? nothing but stock. I just turned it on to see if it would work and yep sure does. just did it so lemme know why it shouldn't work?
Saying it's stock isn't helping me much. I need to know what's different about your system so I can see why mine isn't working. So, what drivers, what settings?
vinyl audio control? haven't seen it. drivers are 5.12.1.3645
settings on medium w/ voip disabled.
After loading the Envy24 Audio drivers the default settings in the Vinyl control panel enable "Stereo Expander", which basically clones the front speakers to the rear.
With this setting enabled you will not get positional audio between the front and rear channels in Battlefield 2.
