SN25P: AcceleroX2 + X1900XTX?
phobic
Anyone know if this combo (AcceleroX2 and a X1900XTX) will fit in a SN25P? I have a 7900GTX on order but I may cancel and go with the above... if it fits. Thanks.
I had an X1900XTX in my SN25P.
A few concerns:
1. It causes system temps to go up quite a bit as well as increase the temperature of the PSU by a fair amount.
2. A stock X1900XTX from ATI barely fits within the SN25P.
I ended up switching back to my X850XT PE in that system which seems more at home in a case like the SN25P. I would probably not put anything bigger than a 7900GT in there - but hey that's just me. I know it does not really answer your questions, but it's just my experience with the power hungry X1900XTX in an SN25P.
Darn... guess I'll stick with my order then. The 7900GTX is smaller than the XTX so it should fit better and is also less power-hungry. I'm probably not ditching the shuttle until the AM2 platform is released for micro-atx motherboards.
phobic watch out for the 7900gtx, you can't really tell yet if it fits or not
