Well you can't fit the NV5 silencer in the SN25P as it rubs against the drive tray so what other than the stock cooler is slim enough to fit? I can't find anything the zalman looks way too fat.
thing is my projector won't do better than 1024x768 so really I won't need to oc or get a monster cooler for a 6800gt just something better than stock.
You could just get a copper heatsink to replace the aluminum one you have on your GT. It's exactly the same, only copper. You could also use the fan from your nv silencer instead of the original. Or, alternatively, you coudl mod the silencer by reducing its height... Zalman looks way too wide to fit btw...
well, the main prob is how the do u reduce the silencers height? i think the dremel is the only solution wtf was shuttle smoking? I don't think an ultra would fit either.
The picture is of my X850XT with an Arctic Silencer 5 Rev2
I also have a 6800GT with an Arctic Silencer 5 that I have used in this Shuttle SN25P. The dremel mod to the drive cages was only necesary to accomodate the Arcitc Silencer cooler as it takes up 2 1/2 slots width.
A stock ATI X850XT or BFG 6800 Ultra with stock dual slot coolers will fit in the SN25P with no mods.
