SMTP Server setting
Azhar
Fixing stupid since 1972
Previously you could change the settings of the Default SMTP Virtual Server inside of IIS 6.0 where you could change the Relay and Permission and so forth.
I just set up a Windows 2008 Standard server a while ago with IIS 7.0. I installed the SMTP Server feature as well. But I cannot find where you can set up the relay or permission for the SMTP Server. I see "SMTP Email" in IIS 7.0 but that doesn't have any advanced Properties in it.
Anyone care to point me in the right direction?
Mucho gracias =D
