CBR said:Damn, that does sound hard. The job search continues.
Thanks.
I soldered a 168-pin LQFP package to a board today at work. The pins are 0.5mm apart, which is something like 19.8 mil.joecool234 said:Surface mount soldering is the brain-surgery of the electronics industry. The average SO SMT IC has 50 mil spacing between pins...thats .050 inches. If you have never soldered before, and this job expects you to solder SMT by hand, you're screwed. It took me like 2 months of practice to get the art down, and that was with a 50x scope. Its practically impossible to do by naked eye. Any other SMT questions, drop me a line.
gee said:I soldered a 168-pin LQFP package to a board today at work. The pins are 0.5mm apart, which is something like 19.8 mil.
I wish everything was as easy as 0.5 mil SOIC and PLCC
mattg2k4 said:Perhaps it just means that you should be able to identify different components and their values on sight.
