SMP stuck on working....
Status
Not open for further replies.
Hito Bahadur
[H]ard|DCer of the Month - December 2006
Guys,
Trying to get SMP client running on one of my systems and it seems to be working, but there is no frame update. My log is below. I let it run all night this way and there was no frame data like on my other systems. This is my only system running Vista so maybe it is a problem with this O/S. Any ideas?
Start log:
Note: Please read the license agreement (fah -license). Further
use of this software requires that you have read and accepted this agreement.
2 cores detected
No directory settings found in registry. Using current directory...
--- Opening Log file [March 25 12:33:17]
# SMP Client ##################################################################
Folding@Home Client Version 5.91beta
http://folding.stanford.edu
Launch directory: c:\Program Files\Folding@Home Windows SMP Client V1.01
Executable: fah
Arguments: -forceasm
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[12:33:17] - Ask before connecting: No
[12:33:17] - User name: hitobahadur (Team 33)
[12:33:17] - User ID: 33BB07B259F1E29E
[12:33:17] - Machine ID: 1
[12:33:17]
[12:33:17] Loaded queue successfully.
[12:33:17]
[12:33:17] + Processing work unit
[12:33:17] Core required: FahCore_a1.exe
[12:33:17] Core found.
[12:33:17] Working on Unit 07 [March 25 12:33:17]
[12:33:17] + Working ...
end log.
Your problem lies in this line of the log
"No directory settings found in registry. Using current directory..."
Make sure you run the install.bat that is in the F@H directory and that you get the MPI has installed successfully twice blah blah but if that happens it should be good to go. Make SURE that you don't set it up as a service as this causes major hassles down the road (I ended up just doing a system restore on a box because I wasn't paying attention)
happen to disconnect the internet (LAN) connection/disable the NIC or something?
eidt: got any FahCore_a1.exe running in the task manager (processes)?
ice: .net 2.0 does not need to be loaded for Vista (as per the FAQ).
It must have been some strange folder issue (maybe rights).
I removed that install and reloaded the program in a folder outside Program Files. Everything seems to work now. Guess I need to get used to Vista.
Status
