smileyscout
- Mar 29, 2005
At what speed your Q6600 is running ?
If the speed is high enough (like 3.0-3.2 GHz), you can assign the SMP client to core 0 and 1 only, assign the GPU2 client to core 2 then install a console client and assign it to core 3 only. You would be looking at about 4500-4700 ppd if thing is configured right.
Assigning cores is essential because if a client is hopping around the cores, it lose efficiency. Locking to a single core (or 2 for the SMP) will minimize this and it will run at peak efficiency.
Xilikon has inspired me to make my build for a dedicated folding machine more [H]ard.
https://secure.newegg.com/NewVersion/WishList/MySavedWishDetail.asp?ID=6218585
- MSI P35 Neo2-FR
- SAPPHIRE Radeon HD 3870 512MB
- Intel Core 2 Quad Q6600
- G.SKILL 2GB (2 x 1GB) DDR2 800
- XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
for $616
I'm also thinking about ditching the retail Q6600 and getting the G0 SLACR Q6600 OEM from Clubit for $223.99
My power supply will be the old one from my main rig AeroCool ZERODBA 620 Watt
I'll use my OEM copy of Windows XP Home since I'm a Linux noob. This program SMP Seesaw Pro which Tigerbiten recommended should balance it all out.
