SMP FAH ConfigDB
drizzt81
Hello all,
I think it would help all of us if we could exchange information regarding out SMP configurations. I propose that the following detail should be provided:
CPU Type (Athlon X2, Core 2 Duo, Core 2 Quad etc.)
CPU L2 Cache
System RAM
Operating System
VMWare Server Version
RAM for each VM
Approximate inter-frame time
Number of SMP instances running
Mac Mini
Core Duo 1.86
1GB RAM
Max OS X 10.4
Not running VM of any kind
Taking about 11 hours or so to finish a WU
1 SMP instance running
Appears to be utilizong about 90MB of RAM across the 4 instances that are running according to the task manager (or whatever it is calld in OSX)
Can you also note how much RAM is used if your not using the VM? I am interested to know.
Suse 10.1 AM2 4200 @ 2.42ghz 512 meg single ch DDR2-800 10min 01sec WU3025
Fedora 2 AM2 4200 @ 2.42ghz 512 meg single ch DDR2-800 10min 15sec WU3027
Suse 10.1 AM2 3800 @2.7ghz 1gig dual Ch DDR2-800 9min 17sec WU3025
Suse 10.1 AMD 4400 @2.65 512meg dual ch DDR-400 9min 29sec WU3027
All are using between 200 and 230 meg of ram total
