SMP client
Savidge
i reinstalled vista 64bit and when i go to install the smp client i enter in my account username and password like normal then i go to run it its telling me that it has rejected my credidentials aka the password account name etc....it hasnt done this before is there a fix like can i manually enter it in the registry...wheres the key located?
Need to take off the User Account Control.
I think if memory serves me you can take it off in the control panel. needs reboot also as I recall.
And just hit enter rather than entering your username. And a reminder, 5.91 and not 5.92 if you're using 64-bit.
216
