SMP Client
bmorton18
I'm trying to run the self extracting .exe in order to install the SMP client but I'm getting an error. The error says "The data section of this self-extracting file has been damaged". Any ideas on how to correct this?
*Edit* Running Windows Vista 64bit.
Bmorton18 if you wish I can email the client to you. Since you seem to have issues, if that helps!
Edit: *nm I'll just pass for now on the SMP client*
SMP FTW!
What is your OS?
If Vista... did your turn off UAC? You can turn it back on later.
Install it to a new folder, not a default folder. Pick something like: c\smp
Good luck. I have lots of SMP's running in Vista.
