Aug 7, 2008 #1 A AMD_Gamer Fully [H] Joined Jan 20, 2002 Messages 18,287 I think i finished the first work unit last night and when i woke up i had this on my screen, and when i restart the client this is what i get.
Aug 7, 2008 #2 Xilikon [H]ard|DCer of the Year 2008 2FA Joined Oct 12, 2004 Messages 15,022 Delete 6.22, go back to the new 5.91 extended until november and wait till Stanford pull the head out of their ass for the botched 6.22 client.
Aug 7, 2008 #3 P Pocatello DC Moderator and [H]ard DCOTM x7 Staff member 2FA Joined Jun 15, 2005 Messages 6,881 Do you have the SMP running at 100%, or did you throttle it down? I suggest 90% or less. Depend on how [h]ard you are. I am at 88% on two boxen --- so far so good. Relic discovered this about ten days ago.
Aug 7, 2008 #4 A AMD_Gamer Fully [H] Joined Jan 20, 2002 Messages 18,287 do i still need to add the -smp switch for the 5.91 client?
Aug 7, 2008 #5 Xilikon [H]ard|DCer of the Year 2008 2FA Joined Oct 12, 2004 Messages 15,022 AMD_Gamer said: do i still need to add the -smp switch for the 5.91 client? Click to expand... No
Aug 7, 2008 #6 A AMD_Gamer Fully [H] Joined Jan 20, 2002 Messages 18,287 wait a second, how do i use the 5.91 client when i run it the console says i should run the install .bat was i suppose keep everything from the 6.22 but just launch the 5.91 client to fold?
Aug 7, 2008 #7 Xilikon [H]ard|DCer of the Year 2008 2FA Joined Oct 12, 2004 Messages 15,022 Yes, you should use the 6.22 complete install then replace the exe with the 5.91 one, run install.bat then you can run fine.
Aug 7, 2008 #8 A AMD_Gamer Fully [H] Joined Jan 20, 2002 Messages 18,287 still not working with 5.91 client, now it says crap about Warning check for stray files, and failed to delete work/wudata deleting current unit and continuing client-core communication error
Aug 7, 2008 #9 Xilikon [H]ard|DCer of the Year 2008 2FA Joined Oct 12, 2004 Messages 15,022 Paste the log, this make no sense with just bribes.
Aug 7, 2008 #10 A AMD_Gamer Fully [H] Joined Jan 20, 2002 Messages 18,287 nevermind it seems to be working now, no way to tell until over 24 hours when first WU is done
