SMP and F@H
’m‚³‚ñ
This is pissing me off. I have a new SMP box, and I have installed F@H twice. However, whenever I boot, I get the anal message 'there is already an instance of F@H running yadda blah blah'. I have each install setup with it's own machine ID. What gives?
Is there some way I can setup each instance to run on a different CPU without using the task manager? At this rate, it would just be easier to go back to a single PIII and ditch the two PII's. :rolleyes:
Mine have worked everytime.
You need two folders.
I use "F@H1" & "F@H2".
Put a console client in each folder or
one console and one graphical client.
You cannot use two graphical clients.
Start each one up and config them as machine ID 1 and 2.
Make the shortcuts to start them from.
Try adding the "-local" switch so they look in their own folder for the startup info.
Dont know if you need the "-local" switch anymore but I use it on my duallies still.
Luck......:D
Stop trying to run two GUI clients and you won't see that message. You can never run more than one GUI, but you can run multiple Console clients.
Edit: Also, if you decide to use the GUI client as one of your multiple clients you need to use the -local flag in the shortcut that starts any Console client.
ChelseaOilman
Alright, thanks guys. ;) I somewhat figured this out on my own last night... :p I just have to reboot to get the -advmethods -forcesse and -forceasm flags running. :p I'll try the -local flag as well.
Now it's a debate between putting two complete mobos in one case and running two AMD systems, a PIII 1 ghz, a PIII 550, and a dual PII 400, or putting the PIII 550 in the dual mainboard with a PII 450 (they use the same bus and are both mult locked, so both would run at their rated speed I think).
I'm going to try using one GUI client and one Console client at the same time, but I think I might just stick with the two consoles. :)
