Carlosinfl
Loves the juice
- Sep 25, 2002
I just installed Smoothwall 2.0 on a spare PC and seemed to have completed the installation. After, i prompted me for a reboot and once back on, it loaded a normal looking Linux login screen.
According to the smoothwall manual (.PDF)
My question now is, am I done with Smoothwall or is there a GUI that I can admin the settings with? What if something I config during the setup must be changed?
Thanks
When SmoothWall Express has been initialised and is ready for use, you
should be presented with a simple Unix/Linux style Login screen. You have now successfully installed SmoothWall Express.
Thanks
