Neither is spilling a drink but guess what? Apple doesn't cover it in their warranty.
You seem to have mistaken a catastrophic incidences with common scenarios.
A PC next to a stove is not a mundane situation.
If Apple tries to go to court and explain that someone smoking is extream abuse I think they will get laughed right out of the room.
A system dying from overheating/shorts/clogged mechanics due to exposure to a lot of smoke isn't abuse?
Man, you guys keep amazing me![]()
There is a huge difference between maintaining ones system while smoking around it by regularly blowing and cleaning it of dust and nicotine accumulation and outright denying ones warranty because you can tell they havee smoked around it. I understand what it is you are trying to get at, but I have yet to read where the user had abused his system by letting dust and nicotine accumulate to the point of causing overheating to the system and resulting in system failure.
She said that the computer is beyond economical repair due to tar from cigarette smoke! She said the hard drive is about to fail, the optical drive has failed and it isn't feasible to repair the computer under the warranty.
First of all hard drives are Hemetically sealed so smoke or any dust particles cannot get at sensitive parts of the equipment.
Although it can be catastrophic, spilling a drink is something extremely common and once again not covered in Apple's warranty.
Oh dude is that is beyond disgusting.
Spilling drinks on computers is not common. Smoking in houses is. Are you done yet?
Spilling drinks is common. Smoking is common. Spilling a drink on a computer damages it. Smoking around a computer damages it over time. If you spill a drink on a computer the manufacturer should not have to replace it. If you smoke around a computer the manufacturer should not have to replace it. The computer was not built to have drinks spilled in it nor was it built to have residue from cigarette smoke build up in it. I really don't understand why you can't get this through your head.
HARD DISKS AREN'T SEALED!!Oh, and I call bullshit on the apple care rep saying that the hard drive was ruined by cigarette smoke, they're sealed.
Also, the obvious being that a spill destroying components also isn't comparable to residue build up being icky. Remember, residue doesn't mean there is damage, nor that any damage is necessarily caused by the residue.
Geez, why do people keep spouting such nonsense? Obviously they don't bother to read the thread/do some minimal research. Stay out of the thread if you are only going to repeat myths.
A spilled drink doesn't necessarily kill electronics either. Spilling a drink is an accident, however. Smoking is abuse. To one's own body, to those around the smoker, to fabrics, electronics and much more.
Nobody smokes by accident. Everybody knows smoking is bad for oneself and one's environment. Those who do not really missed a junction somewhere along the path of evolution.
They're sealed for all intents and purposes of the word. There are no open holes that aren't covered by something. If you want to wax semantics then fine, but a hole with a sticker covering it with a filter to equalize pressure could also be called a seal in the conventional sense of the word. If they weren't sealed then pulling off the sticker wouldn't make a difference, right? an open hole without a cover is fine on a hard drive? stuff a little piece of foam in there and good to go, right?
You don't need to get all huffy there, Mr Thread Police. I didn't say "hermetically sealed", I'm aware of the difference.
Sealed implies no contact between the in- and outside of the HDD. In reality only large and medium-sized particles are filtered out, small particles and air has free access to the inside of the HDD. That isn't 'sealed' other than in the sense that you require tools to get your fat fingers inside.
AFAIK, smoke particles, like dust particles, are HUGE in the world of HD's. That's why they're made in clean rooms, to keep everything off the platters and internal parts.
If what you said is true, then dust would get into the drive and would certainly cause the heads to come into contact with dust on the platters.
http://www.informaworld.com/smpp/content~db=all~content=a778185022Mainstream cigarette smoke generated using an automatic smoking machine (SEM-II) and Kentucky 2R1 reference cigarettes was analyzed for particle number concentration and size distribution. About 90% of the smoke was sampled with an Andersen Cascade Impactor after primary dilution (6-, 10-, or 18-fold). The remainder was further diluted 13,600- to 79,000-fold before analysis with an Electrical Aerosol Analyzer and Condensation Nuclei Counter. The primary dilution ratio and compositions of the dilution streams (nitrogen, laboratory air, dry air, or the vapor phase from filtered smoke) were varied in the experiments. Reliability of the experimental system was checked using NaCl aerosols. The composition of the dilution stream did not significantly affect the size distribution of the cigarette smoke for a given primary dilution ratio. The volume distribution was bimodal, with median diameters for the two modes of about 0.25 and 5 μm. The number concentration was typically 109 particles /cm3, and the supermicron particles contained 5 to 30% of the total volume. Increased particle evaporation occurred when the primary dilution ratio was increased from 6 to 18.
'Dust' come in a large variety of shapes and sizes. The most common types are fibers and dead skin cells, both of which are very large: http://en.wikipedia.org/wiki/Dust
Dust particles can be as large as 500 um, cigarette smoke can have particles much smaller than that:
The smaller the particle, the greater the chance it'll find its way through a filter. For regular dust it isn't such an issue. For the occasional smaller particle it's acceptable as well. The problem with smoking next to a HDD is that smoking produces a lot of really small particles which will get through the filter and will eventually cause damage.
Apple's warranty says that it doesn't cover the Pepsi Syndrome, it doesn't say anything about smoking.
Furthermore, as a consumer product, one would assume it does cover smoke. My TV is covered if I smoke. My phone is covered. My refrigerator is covered. My stereo is covered. Frankly, I can't think of any other piece home electronics that is not covered by the warranty if I smoke in my house.
Apparently there is some consensus here that cigarette smoke residue is catastrophic to electronics, which I suppose is not surprising to me. Each puff of a ciggarrette is comparable to the spilling of a drink, though obviously on a much smaller scale.You seem to have mistaken a catastrophic incidences with common scenarios.
What is really funny to think about is those same elitist people are the same ones that are prolly taking hits from their "smoking" product of choice behind closed doors. Bunch of elitist potheads.
With this statement, you've tried to establish a strong concept of dissimilarity between accidental damage and incidental damage (that which is caused by indoor smoking). Both fall under the category of neglect, however, and thus are quite similar.
I would imagine that Apple's warranty has at least some basic statement regarding neglect and what Apple's responsibilities are when a consumer's Apple product has been subjected to significant neglect.
It's not neglect. I smoked around my PCs for 10 years, and not one of them died. The worst thing that happened was a fan in one PSU (the POS psu that came with an in-win 500 case) died after 4 or 5 years and the fan on my nvidia ti200 died after about 5 years (and, but I only smoked for the first year or so of it's life....and it still works, even without a fan....the PSU still works with a new fan).
And again, I've never heard of a manufacturer refusing to fix a TV because it's in a smokey room. Nor have I heard of them voiding the warranty. Does NCR tell bars that there's no warranty on registers unless the bars are smoke free? Most of those registers are just computers with touch screens.
Smoking isn't good for computers, but IME they generally work fine during the warranty period.
Different companies have different policies.
And Apples policy does nothing for them but push their political view on smokers. Sounds like another good add compaign for PCs.
"Do you live in perfect or sterile conditions? Than a MAC maybe right up your alley, if you dont want to void your warranty. If your not interested in living in a clean room, or have the occasional cigar or cigarrette smoking friend over or if your a smoker yourself, get a PC. We wont deny your warranty just because your not a tree hugging, dop smoking, politically correct Apple fanboi or in current keepings with their ideals."
How exactly can a software company (Microsoft) make those claims about another company's (e.g. Dell or HP) warranty?
We don't know the specific circumstances surrounding this case, however. If you smoke in a well-ventilated room, the damage may be minimal. If there is little to no room ventilation, the damage could be catastrophic.Smoking isn't good for computers, but IME they generally work fine during the warranty period.
I fin it all rather amusing as my mother was a 2-3 pack a day smoker with the PC on her desk and it never had a failure.
