In for one... don't need it, but that's a great price. I'll figure out a use for it.
Why whatever do you mean?Ha.. I notice that you got to edit it your response after you noticed the promo code![]()
Yeah, I canceled after reading quite a few poor reviews. Too bad.review are bad =(
Deal is gone =( missed it.
Hello?
Myself said:All of the PA series monitors come pre-calibrated at the hardware level. My friends PA248Q came with colors spot on, tested with a Spyder 4 Pro. My Dell was quite a bit off. You can correct that with color profiles, but that only works in the desktop environment and with programs that specifically support color correction.
Also, the Asus comes with 4x USB 3.0 ports on the side. The Dell has no additional connectivity.
Build quality is great with both, maybe the Dell is slightly better.
But anyway, mostly the color accuracy out of box and the extra USB ports are what I would've appreciated had I chosen the PA248Q instead of the U2412m.
Anything as in even there video cards? I just got a 660GTX Asus....!!!???
