SMB 3 Multichannel setup/question
x-cimo
Does SMB multi-channel require multiple NICs on both ends?
Server running Windows 2016, 10Gbps intel X520-DA2
Client running Windows 10, Intel Quad 1Gbps EXPI9404PT - Currently only using 1 port.
Switch is a Juniper EX3200 which support LACP
I would like to leverage SMB3 multichannel IO on single file transfer, however most guide focus on the server side and it seems like each NIC need to be on a different subnets.
Is it possible to archive this if the server "only" has 1 10G port?
Thanks
