steakman1971
- Nov 22, 2005
I swear I'm a magnet for disk problems. First, my Drobo craps out on me. I lost some data, spent a lot of time recovering the data I could. Finally get things back in order using Ubuntu and SnapRAID.
Tonight, my BIOS told me one of the drives failed its SMART tests. Crap. Using the smartctl tool, this is my output:
I'm going to pull any data off of it, make a trip to Microcenter and get a 3 TB WD Red drive to replace it. At least I'll be getting a little more space out of the deal...
That drive has been in used for maybe 2 years or so in my Drobo. It's had some use so I guess I can't gripe too much.
Code:
chris@minty:~$ sudo smartctl -a /dev/sdi|grep 'test result'
SMART overall-health self-assessment test result: FAILED!
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.13.0-36-generic] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda LP
Device Model: ST32000542AS
Serial Number: 5XW1XJCR
LU WWN Device Id: 5 000c50 02ea73e8f
Firmware Version: CC95
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Thu Jan 15 21:52:45 2015 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 623) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 105 099 006 Pre-fail Always - 9379031
3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 096 096 020 Old_age Always - 4449
5 Reallocated_Sector_Ct 0x0033 027 027 036 Pre-fail Always FAILING_NOW 3010
7 Seek_Error_Rate 0x000f 075 060 030 Pre-fail Always - 37040243
9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 32556
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 105
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 076 059 045 Old_age Always - 24 (Min/Max 23/24)
194 Temperature_Celsius 0x0022 024 041 000 Old_age Always - 24 (0 14 0 0)
195 Hardware_ECC_Recovered 0x001a 019 019 000 Old_age Always - 9379031
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 55306293903330
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2473439735
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3182492551
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
