SMART capability with SAS connected drives
mwolfod
First a very basic question: Is SMART capability even possible/supported by SAS connected drives?
I have a SuperMicro X8SI6-F Server Board that has MOBO mounted SAS ports that allow a direct connection from the backplane. However, I do not see any settings in BIOS that will enable SMART data for drives connected through the SAS ports (or for that matter, any BIOS settings whatsoever related to SAS ?!?).
Would an add-in card (bypassing the MOBO ports) provide this capability if it is not possible through the MOBO itself?
I am not knowledgable at all on the subject of SAS and Server Board technology in general, so I am hoping for an easy solution to this problem.
Thanks for any help!
If you want to modify any of the SAS settings, you need to go into the SAS controllers BIOS, not the main one. SAS supports SMART as well.
They're still through a separate controller and not the chipset/processor. You need to press whatever key combination is requested on the screen during the period when the controller is initializing.
Crtl -C gives me an "LSI Configuration Utility", which is VERY bare bones; just 2 or 3 settings, and none of them having anything to do with SMART.
Thanks
Have you tried pulling any of the SMART attributes though software in your OS?
Yes.
I am running WHS 2011 and have installed the StableBit Scanner add on (HDD Health assessment) from CoveCube. It reports that no SMART information is available for any of my 14 HDDs.
Thanks.
