Smart/Auto fan question
Hecktec
I have a Gigabyte P35-DS3R and a CoolerMaster Hyper 212 cpu cooler installed. The cooler can max out at 2000RPM, but I've noticed that when the Smart Fan option is enabled in the BIOS, even at full load (Prime95 stress testing), and the CPU core temps are hovering around 54-57C, the fan speed never goes over 1100-1200 RPM. When disabled, the fan goes all the way up to 2000RPM, which is it's maximum rated speed.
Anyway, I'm wondering why the fan isn't reaching it's maximum RPM at full load and high temperatures? Also, should I specify the Smart Fan option to 'Intel QST' or 'Legacy'?
Thanks for any help.
