Smallest widescreen lcd?
Dapperdan
Whats the smalled size widescreen lcd? Im looking to do a project just need a small 12" or smaller screen.
http://www.manhattanlcd.com/product_p/1000.htm
7.2" 1280x768
Did you have a minimum resolution in mind? As there are much smaller ones out there with lower resolutions.
BTW the kit i linked is the LCD panel and a controller. If you bought just the LCD it would probably be ~$180.
You could ask Manhattan LCD if they will sell you just the panel, else try finding it on ebay or something. It is made by Sharp and the model # is LQ072K1lA03.
I'm sure there are many other options, that one was just the first thing i remembered.
