brutalizer
- Oct 23, 2010
I need ECC RAM memory sticks. I have understood that Intel Xeons can use ECC RAM. Or some AMD cpus. If I want to use Intel Xeon, then there are no mini-itx motherboards, I assume? So, I need to use ATX mobos? Or? What is the smallest mobo that supports ECC?
Then I can start to look for the smallest case supporting that mobo form factor. If it is ATX, then I can start to look for small ATX chassis.
