for a 17x17cm mobo, I want something tiny and compact. Psu solution too.
I will only need 1 regular hard drive, no opticals.
Is there anything like this? I don't care if it has the optical slot, say if it would fit a full size hard drive if you use it instead of a slim optical and slim hard drive.
Maby 2 hard drives would be ok too, since it might just work as well depending on how the case expanded to fit the first one.
Should I just make my own custom case or is there something like this?
The case I have liked the best so far is the Travla C134 type ones, which arent redonculously large like a foot print of a foot by a foot 4 inches tall. I dont think a fullsize hd will fit though, even without the optical.
