Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
TJ08-E is fairly big, but I personally really liked it. The drive cage leaves a bit to be desired and it continues Silverstone's weird obsession with screw-heavy PC case build installation. To be honest, mATX is probably more niche than m-ITX. If more motherboards had a slot gap between the two gpus and more mATX cases had five slots, m-ATX would be a lot more popular imo.
TJ08-E is what I'd consider a reasonable size for M-ATX though. Compared to say a 350D it was a baby.
I find it a good size. The Cerberus I've got my email down for though haha. My current rig is in the Ncase M1, ITX, but if I can get something only a little bigger in M-ATX, I may consider that too (or move my brothers computer into it, as he's using my TJ08-E
