Smallest (& Coolest) ATX Case Possible?
v0rtic3s-x
n00bie
I've been scouring Newegg, and just cant seem to find the right thing.
I'm looking for the smallest possible case that will fit a normal ATX board, that has at least decent cooling.
I do so much graphic art, web design etc., that my main gaming system is on constantly, and despite being in a HAF 932 case, the GTX 280 and ASUS Ramapage do get a bit warm.
I'd prefer, for the sake of the longevity of my main rig, to put my older system back together in the smallest case possible.
I have to fit an Intel "Bad Axe", 8800GTX (little big, but the smallest GPU I have) etc. for art, design, browsing etc.
I just cant find anything that's not only a few inches smaller all around than the HAF, even when it's a mid-tower, which at the smallest, I've only found about 2" max smaller in height and width. I'm looking to go as small as possible.
Perhaps the Lian Li PC-A05B?
It's only 15" tall, though 19" long, but I guess the length is alright.
Though it only has on fan, rear exhaust, and it'll definitely need a little more airflow. I'd have to mod that one.
Any other suggestions?
A05b HANDS DOWN, look at the thread just under this one, lots of modded ones that have great cooling.
+1. BTW, it comes with 2 fans and it can fit 10.5" video cards (ie: GTX295). There's only 1 cooling issue (heat builds up above the video cards in the upper rear portion of the case), that is easily remedied via numerous cooling methods.
If you really want a smaller case and don't mind modding the hell out of it, I know in the SSF forum someone took a Microfly case and made it fit an ATX mobo.
Thanks for the feedback.
Yeah, I had actually been looking at/considering the A05b, but wanted a little more cooling than what it offers, without having to mod a case right now (already working on another), so I actually went with the LIAN LI Lancool PC-K7B.
It's only 3" taller, so it's still a lot smaller than any of my other cases, and offers better cooling. Gets hot in my place, plus this will have a 8800 GTX stuffed in there (with a HR-03, but still makes a lot of heat) so this should do the job, and it's just about small enough going by the measurements listed.
I guess I could have just cut out the side of the A05b, since I have a couple extra sheets of mesh, but I've been so busy with other things that I didn't even really consider it. Ah, well... hopefully the Lancool works out to be small-ish enough and with good flow from the extra 120mm fans it has over the A05b.
Cheers.
