Currently the smallest full ATX case I can think of is Logic Case SC-33380B | 3U Standard Chassis 10 x 3.5" HDD Bays . It is almost small enough to be called an SFF case! It's less than 22L. The PSU overhangs three slots.
3U Server Chassis | Full Height PCI Support | Accepts 2U and 3U Power Supplies | Logic Case this page has several cases with the same outer dimensions and different bay configurations.
If you want seven slots? SilverStone Technology Co., Ltd.- GD09 is it, 27L.
If you are fine with three slots and risers then try Logic Case SC-2380 | 2U short depth Chassis for 14.4L. If only one slot is enough then Logic Case SC-13400 | Rack Mountable Server Chassis Case 1U 400MM Short Depth for ATX MB is 7.7L.
The all time champion is IMO the GT3-BH, GT3™ SFF Black Case, ATX, 1 slot, 350W PSU, Aluminum/Steel, GTR TECH at 13.4L discontinued long ago.
