Smallest ATX chassis?
brutalizer
I am looking for small high end ATX chassis. I know of Lian Li PC-V650 (which needs to be redesigned according to reviews on newegg). And Cooler Master Elite 360. Any new models arriving soon?
I think the Lian Li PC-A55B is the smallest ATX case.
If the thermals arnt good for you, then mod it to fit your needs.
Thanx! I will check it up.
Does anyone know if the Lian Li PC-V650 will be redesigned soon?
