crashnburn
- Nov 4, 2007
Small/ Smallest Box to drive 30" 2560 x 1600 LCD via Dual link DVI-D / DisplayPort?
UPDATED REQUIREMENTS:
Since this is such an uncommon combination, now I am thinking in that direction. So let's say I update this as following, what would you suggest:
mITX board (Low priced if possible, but reliable)
- USB 3.0 | eSATA
- GigE RJ-45
Video / Graphics Card (Low low price since I am not gaming at all)
- Supports: 2560 x 1600
- Dual Link DVI-D
- DP | Mini DP
- Small / Compact / Low Profile
- Low Power | Low heat
Bonus if it can drive both together or multiple of the above ports
Bonus if MoBo has Thunderbolt (This might make it more expensive so this is not REQUIRED, but NICE TO HAVE).
ORIGINAL REQUIREMENTS:
a - VIDEO:
- Barebones Box/ Ready Box / Motherboard/ Case:
I'd like find the smallest box/ machine / Barebones or HTPC Media Streamer Box that has
the Video Hardware to support & Drive 30" 2560 x 1600 LCD at Native Resolution
- On board or added Video Card:
Integrated or Dedicated GPU to support this resolution (Intel, AMD or NVidia - No preferences here, any of them will do)
b - PORTS:
- Dual link DVI-D
AND / OR
- DisplayPort
ADDITIONAL BONUS:
- eSATA/ USB 3.0
- LAN/ Gigabit LAN
- WiFi (Optional)
Cistron said:crashnburn said:Is there something out there which can do both:
2560 x 1600p over -
- Dual link DVI-D
AND
- DisplayPort | MDP | Thunderbolt (backward compat with DP)
Preferably Mini-ITX or grow it to Micro-ATX
The older MacMini A1283 had a MDP and mini-DVI. The newer ones have HDMI and thunderbold.
I don't know about the PC world. But it might be easier just to go for a mITX mainboard you fancy and get a low-end graphics card with two ports.
- USB 3.0 | eSATA
- GigE RJ-45
- Dual Link DVI-D
- DP | Mini DP
a - VIDEO:
b - PORTS:
- Dual link DVI-D
AND / OR
- DisplayPort
ADDITIONAL BONUS:
- eSATA/ USB 3.0
- LAN/ Gigabit LAN
- WiFi (Optional)
