small sizing prob @ 1600x1200
rowbear62468
my monitor can do 1600x1200, but, whenever i set the display to that, it expands beyond the borders of the screen...if i move my cursor to the left or right or up or down it will push the screen in that direction....this is kinda weird
prob 2: when i set my display in d3:roe it doesnt fit to the monitor...so if im running 1024x768 or any size, it wont fit to my screen....and, one more i swear, in hl2, if i set the resolution to anything over 1024x768 it pushes out past the screen, much like on my prob above w/the desktop... any help would be great...thanks
It would help to know the monitor and video card...
Have you tried adjusting the size/position of the screen with your monitor controls/on screen menu?
Yeah sounds like you need to go into the monitor properties and shrink the overall size of the screen and reposition the V and H.
envision monitor (viewsonic ripoff) and x800xl agp..cat 5.2
i have tried using the monitor controls and all it does is shrink the viewable screen size
Have you tried uninstall and reinstall the video card drivers?
this happens with me to....windows does a detect of resolutions supported and generally will do this when set higher for me....it happens on my custom and sony rig
now im not sure what i did, but i am currently at 1600x1200 and all within the confines of my monitor...thanks for the quick replys, sorry i dont really know what i did...
