small psu in atx setup, custom case
im builging a custom case on an atx setup with the intenet of making it take up as little room as possible (even if it litterally means tracing the exterior of the case around parts that stick out, i.e. the vid card)
its going to be overclocked. im searching for a powersupply (should it exist) for matx cases or sff cases. i want something small but keep in mind im going to be powering an amd atx setup. heres what im specifically going to have in there:
-athlon xp 2000 tbred core(hope to at least overclock it to 400 mhz to 2ghz and ideally i want ot be at 2.2) on either a nf7-s or shuttle an35n (most likely the shuttle since i already own it)
-9800 pro (considering overclocking this also, but not certain... would like to have the option though should i want to in the future)
-either a laptop hard drive or your standard 7200 8mb cache
-no permenant cd rom drive built into case(only to be used externally for installs)
-no floppy
