CHAoS_NiNJA
- May 26, 2005
I've been pondering the idea of of a small powerhouse, I was looking to mATX, but was pondering if Mini-ITX was possible, with all the things you'd find in a full sized PC, such as heavy overclocking, high end parts, and a ton of the line performance. Is this possible, or simply a pipe dream? This is my first possible venture into ITX, so let me know if I'm simply dreaming to big.
The parts are:
Core i5-3750k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
ASUS P8Z77-I Deluxe Mini-ITX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131840
Antex 620 or Corsair H60 (Undecided)
LIAN LI PC-Q08B
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112265
G.SKILL Ares Series 8GB 1600MHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
eVGA GTX570 (Already owned/on its way)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
Corsair 650TX 650W (Already owned)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
WD VelociRaptor 150GB (Already owned)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236248 (refurb link)
Generic SATA CD Drive
My main questions are:
1) Will I see any performance loss using this (seemly beefy) mITX board over the mATX board I was eyeballing already (Maximus Gene V)? I'm not looking for 1:1 with it, but will it be something noticeable/debilitating?
2) Will my GPU and heatsink fit? I really want something huge like the Ninja, but I'm not sure it will fit with the voltage board sticking out, as well as the RAM. The card is 10.5" and the case is 13.5", but with the fan in the front and the way GPUs are installed in general, would I have the room? Theres also the question of when I take the bottom HDD cage out, if the top one will be too close and perhaps be an issue....
3) Will the motherboard be able to handle overclocking to any respectable degree? The voltage layout looks impressive, even sporting a board just for it, but I can't be sure.
4) Is it really worth it, over going mATX and using the big brother of the choice case, the PC-V354? I want something small, modern, easy to move around to LANs and different places, but something with still a tremendous amount of power under the hood. Would heat truly be my ultimate enemy, will dusting be too much of a nightmare, will the cons outway the pros for going mITX over mATX for a monster gaming system?
The parts are:
Core i5-3750k
LIAN LI PC-Q08B
