Hello there!
It took forever to receive the last piece I needed to complete my Ncase M1 rig - the power supply. A lot of the parts I bought anticipating this were just collecting dust until recently, thus parts prices have been fluctuating a bit since and what seemed to be good deals at the time no longer quite are. Still, I'm very happy with my new little machine here, especially considering it's my first SFF ever.
It's a dual-boot setup: Win10 for VR and streaming (due to my capture card not being supported in Linux), Archlinux as my daily driver. A SSD is shared between the two systems. Arch gets a dedicated (2.5" 7200tr/m) hard drive for /home, as I want my work stuff physically separated from my entertainment stuff. Both operating system use the 4tb HDD for storage (games, movies, etc).
As I'm waiting for a HTC Vive to arrive, I decided to upgrade my previous computer which was not quite beefy enough for virtual reality. My initial plans were to go for a SSF machine so I could easily carry around. I first wanted to make everything I needed fit into a Dan A4 case, but changed my mind when I saw the Ncase M1 since it can accommodate (some) 3-slots mATX boards, and I wanted to keep my PEXHDCAP around.
Previous machine:
- AMD FX 8350
- Nvida GTX 770
- DDR3 8Gb
- 3x 3.5" HDD (1.5Tb, 1.5Tb, 1Tb) + 1x 2.5" SSD (16Gb)
- Antec P180
- and some other stuff I don't quite remember on top of my head
New machine:
- Case: Ncase M1 [218€]
- Motherboard: Gigabyte GA-H110M-S2HP [70€]
- Power supply: Corsair SF600 [130€]
- CPU: Intel i5-6600k [220€]
- GPU: Inno3D Nvidia GTX 980ti, blower [500€]
- RAM: 2x Kingston Fury 8Gb DDR4 HX424C15FBK2 [100€]
- 3.5" HDD: Toshiba MD04ACA400 4 Tb [130€]
- 2.5" HDD: Hitachi Travelstar 7K1000 1Tb [65€]
- 2.5" SSD: OCZ Trion100 240Gb [100€]
- Startech PEXHDCAP [150€]
- ODD: LG SuperDrive HL GA31N [7€]
- CPU cooler: Arctic Freezer 13 [35€]
- Case fan: Cooler Master Silencio FP 120 PWN [15€]
- SATA cables [25€]
- Windows 10 Pro licence [15€]
__________________________________________________________
Ncase M1 next to my former Antec P180.
While waiting for the SF600 I started to sold my previous parts, and had this frankenrig going.
The Arctic 13 is a very very tight fit with the RAM modules.
Everything is a tight fit. There's no cutting corners, the PSU bracket needs to be fully removed first so the motherboard can be inserted.
At this point I understood cables will be tough to handle as well. I already connected the Front Panel ones, stuffing away the extra length behind the motherboard.
Top view.
Not sure if this case fan actually helps much, but it does fit ok. Its dust filter is below the case.
I managed to cram in the other dust filter using a single fan screw. There's quite some tension and it actually holds well.
The SF600 cables aren't very flexible. Custom ones would probably help a lot.
This is how I had to mount the two 2.5" drives so the cables could fit.
2.5" drives in place.
The optical drive I wanted to use has a slim-SATA interface, requiring an adapter.
Unfortunately the power cable simply could not reach it.
So, I went back to another adapter I already had around. But this one needs power from a Molex connector, which hasn't been connected yet (I want to avoid using the SF600 Molex cables, as it's bulky).
Inserting the PEXHDCAP card.
The GTX 980ti is, again, a tight fit. The gap between the card and the chassis fan is a mere few millimeters.
Fitting the 3.5" HDD by pushing cables around.
Gosh, what a mess I made.
Top view, everything in place.
Build complete.
Back panels.
So, what are the results here?
Previous machine:
- AMD FX 8350
- Nvida GTX 770
- DDR3 8Gb
- Antec P180
New machine:
- SATA cables [25€]
Top view.
Build complete.
Back panels.
- The machine is relatively quiet, with a faint airflow noise running through it while idle.
- The Ncase is very accommodating, but the rule of thumb is to basically unscrew everything that might get in your way when assembling parts.
- Temperatures are fine, with a CPU at 22°C when idel and a GPU at 31°C when idle. Running Furmark, the GPU doesn't seem to go over 83°C and throttling does not kick in. More testing is needed at this point.
- I thought the bottom chassis fan would help cool the hard drives more than that, but did not realize the GTX would extend so far when shopping for parts. The 2.5" drives are at around 28°C and the 3.5" drive stays at 37°C (idle).
- SteamVR score of 10.6 (out of 11), no overclocking.
- Unigine Valley score of 3643 (Extreme HD preset), 87 fps average (min: 35fps).
- Small Form Factor doesn't mean lightweight! I need to find some sort of carrying bag for that computer.
