Small form factor/half height PCI-E video card question?
Archaea
I have two machines at my place of business that need half-height PCI-E cards that are capable of dual desktop display.
This if for a GX280 SFF Dell and an HP7600 desktop. When you use a PCI-E video card the onboard card won't work, so we'll need a dual display capable card.
The cheapest card I've found that suites our needs is an X1300 for about $135 from Dell.
I was hoping to find a barebones card with minimal pricetag/ability for our business environment. We need nothing to be run in 3d, we have no need of huge amounts of video memory. These computers will be running network monitoring software on both displays...so we don't need anything fancy.
Does anyone have any cheaper leads outside of this type of card?
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=A0655899
What I was originally trying to find was a half height PCI-E card, probably nvidia flavor, I.E. I was thinking a 5200 or 6200. for $50 or $60 bucks.
wait, why PCIe? Why not PCI? PCI cards are fine for what you're going to do. and anyway, any kind of x13xx anything for 130 is bullshit. I can get myself a recert 6800GS PCIe from eVGA for 100.... and the 6800GS can match my 7600GT.....
first link
http://www.newegg.com/Product/Product.asp?Item=N82E16814103012
is no good because it's not half-height.
2nd link is a great price for the same card - thanks!
I am thinking not PCI because these OEM system manufactorers do crazy things - like remove serial ports, remove PS2 ports, remove AGP ports ect.
I would think in a year or two they may remove PCI slots and we shouldn't outgrow the card in a year or two despite the fact we may phase out the current systems (3 year life cycle)
I can't understand why they don't have half-height PCI-E cards like the 5200 and 6200.
These half height requirement business machines are EXTEREMLY common. You would think there would be more business call for machines with dual display capability.
first link
The package should have a LP bracket (or you buy it for a few $) which you swap over, they have the VGA port on a ribbon cable so it is easy to drop when you go LP.
The manufacturers presumably don't see there being that much of a market, and probably see the extra price of the DMS-59 connector as not being worth the establishment costs for such low end cards. When you get into the mid-range (e.g. 7600GS) it becomes more worth while -- e.g. the new Sparkle 7300GT LP HDMI looks to have DVI+HDMI which may suit if you want dual DVI or DVI+VGA (see here http://www.hardforum.com/showpost.php?p=1030492544&postcount=167).
The Diamond BV300 card comes with a low profile bracket and full height one. I have this card running in my box at the office right now. Great Price and good customer service from them as well.
-Matt
