Small Fan Help???
OneAppleMan
I have a 4 month old Fantom Drives G-Force MegaDisk NAS and the little internal fan is dead. The problem is I can not find a replacement.
From what I can tell using an online ruler. The fan is 47x47x10 mm 12v DC 2 wire. Anyone have any ideas????
Evercool makes a 45mm fan if you want to give that a try. There are also several 50mm fans available. You might have to make some modifications for either but they will be pretty close.
Well what do you know I wend a got a ruler for my iPhone and it turns out that the fan is a 50x50x10mm.
