Small Cheapest SFF case?
videogamer323
Ok I need the cheapest SFF case I can get my hands on, will be hacking it up so dont want to spend a lot of money on it. only thing i need is it has to be as close to 12inches long as possible because I want to mount 11.2in long radiators on the sides of the case. I cant seem to find ANYTHING that is cheap.
Thanks in advance!
You might also want to check out the for sale/for trade sections here, and over at anandtech, to see if anyone's trying to sell a shuttle barebone with a blown motherboard. That would be your best bet, imho. :)
you might also check the forums @ sfftech.com. They always have someone getting rid of SFF parts
You can probably find an old SV24/SV25 system pretty cheap (even cheaper if you are decent with a soldering iron and can replace caps). They are the smallest ones shuttle ever made.
