Small cheap SSD, whats out there?
  • Thread starter Deleted member 184142
  • Start date
D
Guest
Ok, not been shopping for SSD's in a good while and I am looking for a upgrade for my parents aging rig. They do almost nothing on it, other than FF, you know, youtube/FB/mail and that's about it. It is an older dual core, 2GB RAM on an older 250GB HDD that has started making worry some noises. Seeing as nothing else in the system is being stressed I think a small SSD is the best option to add the feel of snap back into it. All it needs is enough room for Mint and maybe 1-2GB of person files, of which they will probably never use, so I was thinking something in the 64GB range, However it seems that you don't really save anything under 120GB and all the names I am use to are all dead. I was thinking about maybe hunting down a used M4 or older Intel?
Sounds like a job for a 120GB Samsung 840 (TLC). Should be able to find one for less than $100.
And how are they? I remember when they first came out that with use they fell on their face hard compared to the older 830/m4's? Granted still better than a mech HDD.
If you want superfluous performance for this application, just get a 128GB Samsung 840 Pro. I'm sure the "do almost nothing" users will appreciate it. :rolleyes:
you may be able to find an older intel 80gb ssd, or those kingston ones which were just rebranded intel ones (they can even be used in raid with the intel one's ;) )
alternatively you might be able to get a hold of an old ocz 60gb, vertex 2 or agility 2, maybe a kingston ssdnow 40gb or something, not sure what used ssd's go for tbh.
I see no reason to get one when I could pick up a 830/m4 used and have a good performing drive. I would rather something new, but like I said, I remember seeing reviews on the normal 840 where it fell behind the older drives by allot.
Sorry, but I would never touch a OCZ etc SSD, lots of trouble with those cheap drives. I want something that can be trusted.
Agreed 100% on the OCZ part.
I got a Kingston SSDNow V300 120GB SSD drive over the weekend at Microcenter for $84.99
http://www.microcenter.com/product/...te_Drive_(SSD)_with_SandForce_2281_Controller
I'm using this to replace my system drive, which was an old IDE, 160 gig HD drive. A drive that was so filled with errors, that I only had about 117 gigs of usable space anyways.
The reviews I've seen for this drive were fairly positive, so it's what I'd recommend, I guess.
Any SSD other than OCZ and has a 5yr warranty will be my choice.
They rarely upgrade so get something they can use for years and warranty if need be.
Any SSD will be fine for them, speed shouldn't be a concern it should be longevity.
