phantommaggot
- Aug 25, 2014
I had a long mess written up, I figured I should condense it. lol.
Currently I have a node 304 with the following hardware
z87e itx ac
4790k (clocked 4.0ghz at 1.05v)
16gb crucial ballistix tactical tracer red/green
sapphire r9 nano
corsair sf600
corsair force LE ssd.
I have NIB (couldn't pass up the deal at the time)
H97m itx ac and 8gb kit ballistix LP
The idea is to put this in the node with an i5 4590 or 4690 non k with my nano while I figure everything out and sell the z97 stuff
The original plan was to liquid cool the node build using a 120mm and 92mm rad and something like an eisberg pump/res. Swap the GPU side vent for a window and go on with life.
Now I kind of want to build something pretty. I want to be able to see everything worth seeing and not see things that I don't want to. But I still need to be able to hold at least 1 3.5" though 2 would be better, 2 2.5" and the rest of the setup. This has made case selection somewhat difficult since I still want to remain as small as possible..
I want to 'trade up' the z87/4790k setup for :
Asus z270i strix
7700k
16gb trident RGB or maybe Ballistix RGB since the grey would match.
I can probably just mod the node and make this happen. I know everything will fit the way I want it to. But, I kind of want the challenge of making it smaller. Plus, the node gets way dusty. I can't seem to even out the fans or whatever else to stop the dust from accumulating on the PSU vent on the side of the case...
I've considered modding a Raijintek Metis. This is the current favorite option.
Theoretically, I could put a slim 120mm rad up in the top / front of the case with a slim fan with a window beside it and be able to see my GPU. But, I loose the 3.5 mount that way and I don't think I can mount the 3.5 between the PSU and Rear/Bottom rad. If I could, that would be great, I could bend a piece of aluminum to hide it and call it a day.
Anyways
I'm not up on all the project cases and stuff out there. I keep track of this forum as often as I can. I'm looking for a case that may be a little more accommodating for what I want. Browsing newegg doesn't help much..
I'm not against a custom case and using a 1u or flex PSU. Maybe having protocase make something.
I don't really want a 'console' case. That said, If I could get one that had the GPU fan on the same side as the cpu fan I'd take a look at it.
And if it starts getting into MATX territory, there's no point either.
Anyways, thanks in advance for any suggestions.
z87e itx ac
sapphire r9 nano
corsair sf600
Asus z270i strix
7700k
Anyways
