Small CaptureOne Photo Build
ExplodingTaco
I have not built a decent rig in a few years so I am out of the loop. I have never built a itx build but would love a VERY small built.
With M2 and one ssd and one video card I should be able to make it all fit.
Any Help?
What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc
Photoshop Actually CaptureOne
$2000 give or take a small amount.
US
Everything: Monitor, Case, PSU, GPU, CPU, RAM, HDD
NO
6) Will you be overclocking?
NO
4k
Now
OEM Win10
