Hi all,
I'm in the middle of upgrading our network at work from Win2k Server w/2k & XP clients to 2k8 Server w/Win7 clients. One of the things I need to do is set up a backup system (the previous admin considered RAID 1 a backup...
) and install a new file server of some kind.
I had planned on just going with a 2k8 box with a shared folder on it that's backed up to a second server, but it's been suggested that I look into NAS devices as well. I'm completely unfamiliar with NAS equipment... My background is in modding and overclocking; my network administration knowledge is all self-taught and I haven't dealt with NASes before, so I'm a little lost, and after searching around the data storage forum a bit, I'd appreciate some advice.
We've only got about 500GB of data right now and about 80 users. I need something that:
-works with active directory so I can set permissions and such
-will run RAID 6 and allows drives to be flagged as spares
-has redundant power supplies
-supports backing itself up to another device (either a NAS or a server)
I was looking at the Thecus N8800PRO; has anyone got any experience with the N8800 or is there something else that I should be looking at?
Also, what do I really gain by using a NAS device instead of just using a shared folder/drive? Is it just that the NAS is probably going to be cheaper and take less time to set up than assembling and configuring a server would (at the expense of having proprietary system that's probably going to leave me up s*** creek if the RAID controller fails), or are there other advantages as well?
Thanks.
Thanks.
