I have an older Abit OTES Ti4200 video card sitting in the closet not being used. When I last removed it it was working perfect, but upon removing it from the m/b I snapped off a capacitor. Specifically a surface mount 1000 mf, 6V capacitor. One of the legs (positive side) snapped off. Since the capcitor in question, was surface mount and had no thru holes my question is this:
Has anyone ever tried a regular thru hole cap and just bent the legs perpendicular to the body and just soldered them to the solder pads on the circuitboard? If you've ever looked for SM caps you know they're next to impossible to find. This should work. I'd like to give this card to a friend whose using a GForce2 440 MX. It would be a good upgrade for him.
Any feedback will be appreciated. Thanks!
