Slurping noise in loop
Ingonuts13
So My W.C rig is running really nicely but I hear random slurping and gurgling at times. THe noises are not too loud just enough to notice. I am thinking part of it is comign from my CPU block which is why my temp readings seem a bit off.
What the heck can I do? Oh and I am using DD Fillport and mc50 and mc6002 with a thermochill 2.120.
Thanks in advance,
My reservoir produces sounds of flowing water. It's actually quite soothing :)
Probably just some air trapped in the cpu block. Can you tip your system around a little (CAREFULLY) to get some of that air out?
As does mine. He's no using a res though, so I dunno..
Yeah I have been tipping it and some bubbles have started appearing near my fill line. I think the system just needed a few days to bleed properly.
