I have had a Rebel XT for a long time. It is my first SLR and I can't help but to feel that my expectations have not totally been met. What you can see in the viewfinder is only like 95% (if even that) of the picture you actually take. I can adjust to this concept however I have several lens and the offset is different for each lens. It would be idea if you got another 2.5% of the picture on all sides but that is not so. It seems that is almost the way it works with one of my lens (except for the bottom). I can learn to adjust to this however with the lens I use most the time, the offset is just bad. You get like an extra 8% of so on the top (I guess I can call it that) and 0% extra anywhere else. I have taken countless pictures that are way off center because of this weird offset.
Is this only a problem with the Rebel XT because it is the value line SLR and possibly comes with a cheap viewfinder or is this a problem I would also have with a 30D?
