Hey guys, finally got my htpc up and want to slowly build up a rather large file server. I have a few questions.
Background to what i am doing, I have a dvd fetish and buy alot of dvd's on impulse, I only have about 120 dvd's now, but that was all bought in about 10 months. I want to keep full dvd's on my computer (keep special features, subtitles, ect) so i plan to do direct rips.
Firstly, i have never done anything with arrays, is there an array that makes multiple drives into one partition? I would rather have it as one partition as i plan to make a custom program and would like all the information on a single drive so i can sort things through folders.
Secondly, I know with the first thing, wanting a single partition, this is most likely not possible, but is there a way to add drives to the array without reformatting, As i slowly build this array, money is a factor and i plan to start with 2x250 and add new drives when i need the space.
and the last question, I plan to keep the drives in my htpc, untill they no longer fit. At that time i plan to build a seperate file server. But the computer i am using for the htpc (xp 1700+ on an XFX mach4) does not have sata controllers, I dont really want to spend $350 on a raid controller right now since i could use that money to buy 2 more drives, so i plan to buy a couple cheap $20-$40 2 channel sata controllers, is there a way to link these 2 together to get 1 raid out of both cards?
and then in the future, is there a way to combine the $350 raid controller (8 channel) with onboard 4 channel on the mobo i plan to buy to have a 12 drive array (rather a 10 drve, but that would be the same thing).
Thanks
Jesse
Thanks
Jesse
